AF display not going below 12 or above 19
DOHCAccord
Post by DOHCAccord »
Hello,
while datalogging my s300 display will not read below 12 or above 19 for AF.
My wideband will go to as low as 10 before showing rich and 20 before showing lean...
The wideband is accurate but the display will not show the higher or lower numbers...
any ideas on this?
Re: AF display not going below 12 or above 19
You need to provide much more information such as what wideband you are using, what input you are using on the s300 and exactly how you have it all wired.
DOHCAccord
the wideband is the PLX m-300 and is wired into the ecu via the D10 input
Have you removed the resistors as it says in the help file?
http://www.hondata.com/help/smanager/wi ... ub=eld+d10
DOHCAccord
i opened the case and the resistors are in place.. how do you recommend removing them from the ecu?
Luke
Post by Luke »
DOHCAccord wrote:i opened the case and the resistors are in place.. how do you recommend removing them from the ecu?
solder them out. easy as that.
Or cut them out with a wire cutter.
