K-Pro VSS Problems
Rdriver
K-Pro VSS Problems
Post by Rdriver »
K-pro V3 PRB
v3.2.5
k24a2 with 05 type s trans
02 harness
K-tuned speed converter
98 civic
I'm using a k-tuned speed converter for my 05 type s transmission. The problem is that my gauge cluster is dead on mph, but my ECU defaults to 49mph which locks my reverse solenoid. Everything is wired properly and the vss and the k-tuned box obviously work because my cluster is getting the right signal. The signal wire to the ecu is not broken, what should I check next?
Re: K-Pro VSS Problems
Change the setting the KPro for the speed sensor so that it is not set to constant 50 mph
Rdriver
Post by Rdriver »
It's set on normal. That would be the right setting since the k- tuned converter is changing the signal...right?
Double check and upload again since a constant 50mph would indicate the KPro was set to give a constant speed.
Rdriver
Post by Rdriver »
I've uploaded 3-4 times, and tried a couple different cals. I thought that when a speed sensor signal was not detected 49mph was the ecu default. No? Also when I load the stock k24 base map (since updating to the newest version of kpro) It says that my cal is outdated and to get a later version. What does that mean?
That means that you have not uploaded the calibration to the ECU. It sounds like all you have done is open the calibraiton in the software. You must click on the upload button after you make any changes.
Rdriver
Post by Rdriver »
I have uploaded the calibration more than once and this is the warning message I get "The calibration in the ecu (3.2.0.0) is from an older version of kmanager. Please upgrade the ECU calibration before datalogging from this ECU."
Download the most recent beta version of software from the downloads section of the website ad then upload the calibration to the ecu.
Rdriver
Post by Rdriver »
Isn't the software version that I have listed in my original post the latest?
It is, but the message you are getting is telling us that the calibration has not been uploaded to the ECU using this new version of software.
Rdriver
Post by Rdriver »
I have uploaded several calibrations and I'm still getting the same message. I even deleted my calibration from my laptop, then plugged in my flash drive and added it back. This was a mistake now when I try to open the calibration it causes an error and the software shuts down.
What is the exact error you are getting?
