D17 knock sensor
TALONTRAX
D17 knock sensor
Post by TALONTRAX »
I see that the d17 knock sensor is not compatible with Kpro. Can I replace my stock d17 knock sensor with one from a 02-04 RSX,or other compatible application to continue to have knock sensor function ?
Re: D17 knock sensor
No it will not work properly as the Knock control is tuned to work with a certain engine size and design. The D17 and K20 are very different designs.
TALONTRAX
Post by TALONTRAX »
Ok . . . thanks. So no knock sensor/protection for thr D17. No problem Thanks again
