b18c4 s300
deivir123
b18c4 s300
Post by deivir123 »
I get an error in 13 ,16 and 41 i have the lambda probe off the injectors and changed the map sensor and yet I am still leaving the same errors can be that I have the lambda probe with the cut wires? ECU P28
Re: b18c4 s300
What is the complete code on the side of the ECU?
deivir123
Re: b18c4 s300
Post by deivir123 »
What number refers? What the switchboard mia or hondata that led installed?
deivir123
Re: b18c4 s300
Post by deivir123 »
Spunkster wrote:What is the complete code on the side of the ECU?
Re: b18c4 s300
Type out what the sticker on the side of hte ECU says.
deivir123
Re: b18c4 s300
Post by deivir123 »
Spunkster wrote:Type out what the sticker on the side of hte ECU says.
37820-p28-g01 766-210908 aru
Re: b18c4 s300
You will have to disable the baro sensor and the injector error in the misc section of the parameters window.
Are you still using the OEM narrowband o2 sensor?
deivir123
Re: b18c4 s300
Post by deivir123 »
Spunkster wrote:You will have to disable the baro sensor and the injector error in the misc section of the parameters window.
If I have the series of the o2 sensor, it is worth it because it lets me move from laps
deivir123
Re: b18c4 s300
Post by deivir123 »
I can already upload of laps
deivir123
Re: b18c4 s300
Post by deivir123 »
hello good and fix this issue I have a problem I put the contact q car and I read the exchange I make a mistake when the ignition breakdown in the motor box and not read it off the ground to the battery and replaced but I stop the car the same problem arises again it can be?
Re: b18c4 s300
I'm sorry, but I do not understand your question.
