Help log upload problem!
Exiged
Post by Exiged »
Ok I'm using the newest version of kpro
The car runs. I can download catalogs and delete them.
I am trying to upload a new calibration but I keep getting an error.
I tried to upload a different tune I got an error
I switched usb cables and I got an error
I switched computers and I got an error
I restarted the computer And still got an error.
I uninstalled and reinstalled kmanager and got an error.
I disconnected the battery and reconnected the battery and still got an error.
I tried to delete the ecu and it gave me an error and wouldn't do it.
When I do try to upload to the ecu I do hear a slight click in the ecu and then get the error...
Please help!!!
Exiged
Re: Help log upload problem!
Post by Exiged »
Just an update. I checked all my grounds and they were fine.
I tightened the screws on the kpro to the ecu Still have an error
I tried downloading the tune from the ecu and I got a warning saying the binary image in this ecu is security protected, blank or corrupt, and cannot be downloaded.
Car is still running fine and I can do datalogging
Still can't upload!
I tried clearing the security and I got a failure message too.
What is the error?
Be very careful when tightening the KPro screws as this may bend the circuit board.
Exiged
Post by Exiged »
It says "upload error" when I go to upload I do hear a click but it's one of the relays.
Exiged
Post by Exiged »
It's 05005213 it was swapped into a brand new ecu last year by xenocron
To find out if it is a dmaged ECU, K-Pro board, or both, you can swap the K-Pro board to a known working ECU that already has a K-Pro and see if it works properly, if it does then you know it is the ECU. You can also try the workign K-Pro from teh other ECU in your ECU and see if that works.
