hondata ecu for "zc"?
jerjer27
Post by jerjer27 »
ok im tring to find out if hondata can suport a "zc" motor with a t25/t28 turbo kit which is going to be stuffed into a 88civic dx if it can be done what other info do you need? and how much would it cost?
DaX
Post by DaX »
You have some choices:
1. Stay OBD-0 and use a Hondata Stage 2/3/4 with a PR3 or PW0 ECU.
2. Convert to OBD-1 and use a Hondata S100 or S200 with any of the OBD-1 ECU's listed here: http://www.hondata.com/ecus.html
For pricing, go here: http://www.hondata.com/products.html
Actually, just go here and start reading: http://www.hondata.com
The PR3 and PW0 will not run a non-vtec engine. You may be able to convert to OBD1 and get this to work, but you will need an OBD1 distributor, and this is not an engine that Hondata supports. You may be able to get it to work though.
jerjer27
hey dax?
Post by jerjer27 »
how can i get that dancein chic thing you got on the side there? ive been staring at it for about a hour now( its been a loooong deployment) but anyways thanks for the info if hondata doesnt support this engine where can i turn to?
