problem help
josephdavid
problem help
Post by josephdavid »
Flashing red light will not rev past 4000rpms no cheak engine light here's the twist if I keep cycleing the key I can get a green light then car runs fine it can take a while to get a green light I have s300 v2
Re: problem help
What is the serial number on the s300 board inside the ECU? From Help, About, what version of software are you using?
josephdavid
Re: problem help
Sn is 22795 I have newest program for the form
Re: problem help
what is the actual version number when you go to Help, and click on About?
josephdavid
Re: problem help
2.2.7
Re: problem help
Close Smanager, then reopen it, then go to new Calibration and select any one of the calibrations listed there. Upload the calibration and when it is done turn the key off then back on, does it work and will it datalog with the key in just the on position?
josephdavid
Re: problem help
No it did not work and it wouldn't datalog.. had to cycle key 15 Times to get a green light then everything works qhen red light flashes it will not connect
Re: problem help
Just for testing can you swap your s300 into someone elses ECU that has an s300 and see if it does the same thing in a different ECU?
