Solid Red light with non erasable CEL
rudebwoy
Post by rudebwoy »
my car 1996 CRX Del Sol
B20/Vtec turbo tuned to 662whp on E85
using Hondata s300 v1 and Hondata CPR kit
car ran perfect at my first race other than the destroyed transmission and axles.
came back and tried to drive it off the trailer (I replaced the trans/axle at the track) and stall it (driver error) after that it would not start with solid red light and check engine light that is not showing a fault, I erased the ECU and reload the map and problem went away, and car starts and run fine, parked the car and stalled it on purpose to see what happen, and the same problem returned.
I don't have my serial number on hand car is 20 miles away.
I am running the latest software.
what else to do?
Re: Solid Red light with non erasable CEL
I will need the serial number and the actual version number of the software you are using.
rudebwoy
Post by rudebwoy »
serial # s300-12 207
version 2.2.7.0
this problem happen out of the blue.
Send an email to support <at> hondata.com with the following and I will issue an RMA and give you further
instructions (include a link to this thread):
Name:
Address:
Phone:
Email:
Serial#:
Description of problem:
rudebwoy
Post by rudebwoy »
I just did a last test on a stock integra using the stock base map same issue.
ok will send the email.
