KManager V1.0.18
KManager V1.0.18
V1.0.18
* Fixed help->contents crashing application
* Change boost cut so that it is removed when engine speed drops below 2000 rpm or the throttle is released (previously rpm and MAP was used)
* Removed used options (some units, display size).
* Added engine overheating protection.
* Added the option to disable iVTEC
* Prevent the use of % symbols in the notes field.
* Validate air temperature compensation when loading calibration.
* Added two cybernation calibrations.
Download here
krystar
Post by krystar »
why was the size option removed instead of just making it work? do you plan on putting it back in later?
the functionality of the software is great but the interface is hard to work with. it's just some really small things that'd make the software much easier to use. user configurable fonts and colors. right now the red on black of the display window is hard as hell to read when there's sunlight.
it would be really useful to have just the normal windows function available. tiling, cascade, docking.
please do consider these when next version comes along :)
