Boost control quit
9queSt
Boost control quit
Post by 9queSt »
The boost control quit working on me at the track last night.
Hondata/Mac solenoid.
I tested the pwm output, the solenoid didn't make a sound
The solenoid has power.
The solenoid clicks when 12v and ground is applied to it.
The wire from A11 to the solenoid is good.
It must be something inside the ecu. What can I test??
95 civic
gsr engine
Golden Eagle block
Hondata s300
Forged pistons
Eagle rods
E85
Gsr crank
One off Cams
Re: Boost control quit
Please post your calibration you are using as well as a datalog showing the problem.
9queSt
Post by 9queSt »
I was using version 2.2.4 when it quit working.
I just downloaded version 2.2.7 and clicked on the test function for pwm.
It stared clicking immediately. sounds like its fixed.
