diagnostic codes?
frydrce
diagnostic codes?
Post by frydrce »
Will flashpro display codes for the EPS system? Can they be reset from it or only an HDS?
Re: diagnostic codes?
FlashPro only communicates with the ECU.
frydrce
Post by frydrce »
Doesn't flashpro add idle speed when the eps is checked?
What exactly do you mean?
frydrce
Post by frydrce »
If I go to misc parameters and select EPS enabled it will increase idle speed when turning correct? So in theory does it not communicate with the EPS? The reason I ask is because my steering drives to the left and I beleive I need to do a re calibration of the eps. Could this be in a future revision? Or is there too much liability?
This sounds like you need to have an allignment done and has nothing to do with the ECU or the FlashPro.
frydrce
Post by frydrce »
I would say you were correct but the steering actually drives itself to the left while stationary. I'm not saying it due to the flashpro just curious if it would reset the eps control module. The hds would short pin 4 and 9 of the dlc. Just wondered if this was possible in the future. I know it can be done with a wire. But it would be nice to do a reset.
The FlashPro cannot do this and there is no plan to do so in the future. It sounds like you need to take your car to the Honda dealer to get this issue resolved.
