Kpro IGN off, no fuel pump...help please
integradude18
Post by integradude18 »
Ok I trying to crank my integra up for the first time but cant....
I have done:
-all engine grounds installed from hybrid racing ground kit.
-Engine Harness ground to valve cover
-double check my hybrid racing conversion harness
-used my brothers main relay from his integra
-unplug plugs to see if that would help
-double check my charge harness wiring
im at a point where I don't know what to do now....
Weird thing is when I was doing that swap nearing the finish I plug the kpro up and ign was online and I was able to upload a .cal file but now I cant...
So no fuel pump priming and no ign on in kpro
Re: Kpro IGN off, no fuel pump...help please
Try your ECU in a known working car. If the problem persists then it sounds like your ECU has been damaged by improper wiring.
