car goes lean on wot
rasheedn
Post by rasheedn »
Hi guys,
This is the 1st flashpro car i tune and i am having a weird problem
when going wot the car goes from target 12:5 afr to 14:00 afr
i tried to re-sale maf and to add stupid amounts of fuel and its still reading lean
this is on the stock o2 sensor (i read its a wideband and should be good for the job)
I tuned the closed loop and the corrections are very minor around 1-3% max
the car is stock euro fn2 except for an aem intake
any ideas?
Re: car goes lean on wot
Without the calibration and datalogs showing the issue it impossible to speculate.
rasheedn
Post by rasheedn »
here u go
this is a stock file with cl maf slightly tuned
nunoctr
Post by nunoctr »
You have to tune fuel in the correct way with the AFM calibrations.
Go to sensors and AFM flow. Go to mass flow and add 6% or 7% in all the mass flow values above 3,71v (don't change the voltage values. I seen you have change this voltage before).
If your car is still lean you have a dead o2 sensor.
rasheedn
Post by rasheedn »
this is what i did on a previous file
and it stayed lean
so dead o2 sensor right?
cant be that lean without melting something (client has been bashing the car for a month and its like this)
nunoctr
Post by nunoctr »
No it can't. It is running with 86% duty cycle. I think that when you install a new sensor you will see that the car is running rich.
rasheedn
Post by rasheedn »
replaced the o2 sensor and same thing
im looking closely at the afm reading and it looks messed up
maybe the sensor is old and needs replacing?
rasheedn
Post by rasheedn »
i just noticed that during a wot pull the s.trim goes up to 46% and the car hesitates during this period
i thought the s.trim would not be active during wot driving ??
Check the wide open throttle determination pressure in the closed loop section of parameters.
nunoctr
Post by nunoctr »
rasheedn wrote:i just noticed that during a wot pull the s.trim goes up to 46% and the car hesitates during this period
did you change the values in the wot lambda adjustment tables?
nunoctr
Post by nunoctr »
rasheedn wrote:replaced the o2 sensor and same thing
your map pressure is very low at WOT close to 900 when it should be close to 1000.
Also is this car running the last version of the FP manager? or an old one? If it's old, download the last one FPmanager and upload again the cal.
rasheedn
Post by rasheedn »
no i didn't
am i supposed to???
rasheedn
Post by rasheedn »
ummm so what does that mean if my map pressure is low? ?
yea latest versions installed
Shunjy
Post by Shunjy »
Same problem on two FN2 Type R
On MAP tune
After 6000 rpm the AFR sensor reading go up 14.7 !!! with last update !
Can you post the calibration and a datalog? We have not made any changes to the FN2 since February, so it seems unlikely that the last update caused a problem.
