2005 Integra Type S and new K Pro Engine Won't Start
mrbenson
Post by mrbenson »
Hello,
I just received (08/08/13)
K-Pro Serial #13019
ECU part # 37820-PRB-A08
serial #2068-800126-0D21
which I ordered from my dealer here in NZ (FortyOne Automotive) for my 2005 Australia/New Zealand Integra Type S (K20Z1 6MT). I would like to confirm that I received the correct product. There was no adapter harness included in my box. When I installed the K Pro, my engine will crank but not turn over.
I am using K Manager 3.2.4.0 and calibration is attached. My mods are: RBC manifold, Injen CAI, 4-2-1 race header, Hondata IMG
I get the following error codes when I attempt to start the engine:
39-1 PO600 Multiplexer not present
56 POO10 VTC Oil Control Solenoid Valve Malfunction
My car runs fine with the stock ECU.
Thank you for your help.
Edward
Re: 2005 Integra Type S and new K Pro Engine Won't Start
Post a picture of the inside of your original ECU from the vehicle.
mrbenson
Post by mrbenson »
Spunkster wrote:Post a picture of the inside of your original ECU from the vehicle.
The ECU will have to be sent back to be modified and you will have to use the adapter harness for it to work. You will have to purchase this through your dealer. It was not order for an 05 RSX. There may still be soem thigns that do not work correctly as we do know know much about these Australian vehicles.
mrbenson
Post by mrbenson »
Thanks for your help with sorting this out Spunkster.
Will you please tell me what exactly I need to order so that I can tell my dealer? Is it the modification of 02-04 K-Pro to 05-06? Thanks again.
That is correct.
