Fuel cut at part throttle
Boyle.r
Post by Boyle.r »
I'm having a problem where at small throttle angles 2-3% the ecu is cutting fuel so I cannot maintain a rev unless I increase throttle. I read about adjusting the values under parameters, "Overrun cut off" which I done, first tried 15, then 12 but still it cuts fuel. My TPS is scaled correctly etc so don't know how to over come this.
Re: Fuel cut at part throttle
Boyle.r
Post by Boyle.r »
Spunkster, I will fill that out when I get home this evening. Would it be possible to have a TPS threshold for fuel cut like with s300? It would solve this issue for a lot of people as it seems to be very common from my reading on here.
