2008 TSX VTC
tH3 eL
2008 TSX VTC
Post by tH3 eL »
Will a 2006 RSX Type S VTC mechanism, part number 14310-RBC-003, work with the Flash Pro? (Vice taking the existing mechanism to a machine shop.)
Thank you.
Re: 2008 TSX VTC
Zoro2006
Re: 2008 TSX VTC
Post by Zoro2006 »
tH3 eL wrote:Will a 2006 RSX Type S VTC mechanism, part number 14310-RBC-003, work with the Flash Pro? (Vice taking the existing mechanism to a machine shop.)
Thank you.
it will work, just don't go past VTC 45 in Hondata as you won't gain more and will have bigger clearances.
Known as Vaikis_
angelf1974
Re: 2008 TSX VTC
Post by angelf1974 »
Thank you.
The ECU cleans the VTC mechanism occasionally. When it does, the VTC reaches the mechanical stop at 50º. The good thing is that occurs at low rpm (2000 - 3000) but we must not forget.
Honda Accord CL9 (Spain)
rjrawlings
Re: 2008 TSX VTC
Post by rjrawlings »
The ECU cleans the VTC mechanism occasionally. When it does, the VTC reaches the mechanical stop at 50º. The good thing is that occurs at low rpm (2000 - 3000) but we must not forget.[/quote]
Well theres something i didn't know. :)
angelf1974
Re: 2008 TSX VTC
Take a look:
