Throttle plate tables
FlashPro questions & answers specific to the 2010 CR-Z (US, Euro & Asia)
tp
Post by tp »
Hello
Any reason the throttle plate tables have last 4 columns at 100% TPS on 2011 and 120% on 2012 cars jumping from 69%?
It really doesn't give a smooth transition as we can only realistically work within 2/3 of the effective table. Can you expand it so its similar to all the other cars?
Re: Throttle plate tables
They are like this because that is how they are from the factory. You can always edit them. This may be updated in a later version of software.
terenceng
Post by terenceng »
Other calibration like Japan, Euro or US the Load Index is not editable, only Asia Calibration P020, the Load index is editable.
I am confused when editing the load index, i can see there are 6 option in the drop down panel (kPa, inches, mbar, bar, Kpa, psi, kg/cm), but which one shall i use?...
thanks.
It is completely up to you. Use whatever unit you are comfortable with.
terenceng
Post by terenceng »
May I know what is the default value?
There is no real default. You just choose the units you are most comfortable or familiar with.
terenceng
Post by terenceng »
This issue was solved in Hondata Flashpro Manger version 1.6.3.0.
Thank you.
