timing table maybe?
da1hardee
timing table maybe?
Post by da1hardee »
I'm working with a B18C1 block, JE 11.5:1 pistons. B16 head, JUN 3 cams, AEBS intake, 65mm throttle body, header, AEM fuel rail, walbro 255 and RC 310 injectors. When I change the injector size to 310 the car stalls out and dies. Thanks in advance.
02busa1
Re: timing table maybe?
Post by 02busa1 »
Are you changing the injector size while the car is running? If so, change the size - upload - then start the car. Also you should have a sheet that came with the injectors to set the dead times.
da1hardee
Post by da1hardee »
i changed the injectors to the dead time they supposed to be....the car leans out and dies.
The dead times you are using may be wrong.
da1hardee
Post by da1hardee »
Ok I'll have to contact RC to get the dead times.
