New RBB-316 TSX ECU
Rick66
New RBB-316 TSX ECU
Post by Rick66 »
I've got a strange problem with my TSX new ECU that is not even mentionned on Hondata's website.
My TSX ECU was affect by salt and changed under the 04-08 ECU recall that Acura issued back in April this year. For those who don't know, the recall affects areas where salt is used on roads and could get into the cabin then into the ECU to kill it as in my case.
Since my ECU was dead because of corrosion, Acura Canada proceeded to replace my OEM 2006 TSX 37820-RBB-A04 with a new 37820-RBB-316 ECU.
I've searched, but found no information about this ECU? Is this ECU supposted by Hondata's reflash? Any information?
Re: New RBB-316 TSX ECU
We do not know and will have no way of knowing until we actually see one of these ECUs here.
Rick66
Post by Rick66 »
Spunkster wrote:We do not know and will have no way of knowing until we actually see one of these ECUs here.
Can we arrange something with my ECU?
I could provide it, but I bet Hondata will just ignore it...
If you send it in for the reflash, we can attempt the reflash, but until we get it here there is no way to know if the code in the ECU is updated or the same as the old one.
