need help with a kal
syn_ej6
Post by syn_ej6 »
Ok I'm using a prb ecu with kprov2 I have a k20a3 engine with a 06 type s trans
I'm using the high octane kal my problem is how can I disable the reverse lockout because the ecu thinks it's a 5 speed trans and won't let me go into reverse while the car is on which is annoying when daily driving someone please help this is the only kal I can use that makes the motor run decent or if someone can get me a kal for a k20a3 with a 6spd trans, stock type s manifold and injectors with a hytec header thanks in advance
Re: need help with a kal
You will have to add the wiring for the reverse lockout solenoid.
syn_ej6
Post by syn_ej6 »
Spunkster wrote:You will have to add the wiring for the reverse lockout solenoid.
with another tune it works fine
syn_ej6
Post by syn_ej6 »
thats crazy 84 views and not one person even tried to help me out its cool thou
What vehicle is this in, and what engine harness are you using?
