kpro won't hold the base map
bpjeffrey
Post by bpjeffrey »
I have an 05 EM2 with a bone stock K20a2 swap, the only aftermarket parts I have is the conversion harness from Hybrid Racing and the Kpro. From the initial install the kpro wouldn't and won't hold the base-map once I turn the car off for 10min+!
Re: kpro won't hold the base map
The calibration is uploaded to the ECU and it cannot loose the calibration even if the ECU is unplugged. Please give more detail of exactly what is happening.
http://www.hondata.com/forum/viewtopic.php?f=12&t=3629
bpjeffrey
Post by bpjeffrey »
Okay Spunkster, When I installed the swap I completed in one day so I saved the start-up til the next morning. I uploaded a base type's map! It idled perfect and didn't drive it until the coolant system was bled. When I took it around the block it was running perfect. I turned the car off to clean my work space and when I went to start it it wouldn't rev past 4 and all the settings went back to "default"
Please provide all the information in the link above.
bpjeffrey
Post by bpjeffrey »
Getting Info now
Shacqem2
Post by Shacqem2 »
- Serial number Kpro-12632
- ECU part number-37820-prc-013
- Serial number- 2070-300353
- KManager version-3.2.4
- the calibration (as an attachment)
- a datalog of a problem (as an attachment)
- Vehicle- 05 honda civic with a Bone stock k20A2 swap with a hybrid racing conversion harness and Kpro
- Problem- From the initial install the kpro wouldn't and won't hold the base-map once I turn the car off for 10min+!
-When and where you got the K-Pro?-August 22, 2013 from Project Jdm
bpjeffrey
Post by bpjeffrey »
Info is up Spunkster
Are there any error codes when it only revs to 4000 RPM when checked with datalogging?
Shacqem2
Post by Shacqem2 »
P0113 IAT sensor high voltage
Daughter board communication error
Shacqem2
Post by Shacqem2 »
The multiplexer was disabled.. and then I enabled it and it revs past 4k and now my temp guage works..
Shacqem2
Post by Shacqem2 »
So what im guessing is that everytime my vehicle is turned off it disables the multiplexer..
The daughterboard communication error is your biggest problem and you will also need to resolve the IAT error as well. Check your battery voltage when cranking as it is probably too low and is causing the error. Your calibration is not being erased.
