4 bar with automatic
UTAH TSX
Post by UTAH TSX »
Scott dyno tune.fpcal
this is the calibration when the transmission free reved, we melted pistons and stopped the datalog got cleared
Is the new 4 bar sensor different internally or is the case just different than the older square one ??
Re: 4 bar with automatic
You need to enable the AFM in order for the AT computer to work correctly (and it should be in the intake pipe and reading the air flow). You can have both the AFM and 'Use MAP Fuel Tables' enabled at the same time, and it will use the correct MAP fuel tables.
Also the AT computer will not read the manifold pressure correctly with a 4 bar MAP sensor. If you are below 14 lbs boost then use the stock MAP sensor.
UTAH TSX
Post by UTAH TSX »
Hondata wrote:You need to enable the AFM in order for the AT computer to work correctly (and it should be in the intake pipe and reading the air flow). You can have both the AFM and 'Use MAP Fuel Tables' enabled at the same time, and it will use the correct MAP fuel tables.
Thank you for the help with this, Great customer service
That fixed it drives and shifts perfect now
Thank you
Jeremiah
Post by Jeremiah »
Question,
I have an 09 TSX, manual transmission and am about to turbo charge mine, and also have the 4 bar map sensor.
I will be running the stock rotating assembly, is the 4 bar map sensor of no value, as I do not plan on exceeding 12 to 14 PSI on the stock block?
Thank you
The stock sensor will only read to about 10 or 11 PSI, anything over that will read off the last value in the table for that reading. Overboost protection will also not work above 11 psi with a stock sensor.
Jeremiah
Post by Jeremiah »
Thank you for the quick reply sir.
I will have to use the 4 bar I have.
