Ignition retard issue - please advice
gerar348
Post by gerar348 »
hey guys my ignition drops randomly after vtec! this is a k24a2 supercharged,
if you have any thoughts please point them out,
so far i have put known working (from another running rsx)
crank sensor
cam sensors (both)
coil packs all 4.
replaced complete engine harness with one fresh of a 2002 rsx type s.
I am also not getting any check engine lights,
any thoughts are appreciated.
This killed my tuner when i went to tune this past weekend, after hours we still can figure out the random ign changes, please advice.
thank you!!
Re: Ignition retard issue - please advice
In the 'Knock Ignition Limit Low' (and high) tables make sure there are no negative values.
gerar348
Post by gerar348 »
Hondata wrote:In the 'Knock Ignition Limit Low' (and high) tables make sure there are no negative values.
Sorry i am not much of a tuner, i dont know what the values should be, my tuner is 2 hours away from me and he said for me to make sure ign is not breaking up any more before i go back down to try to retune. i am trying to figure out the issue before i waste another day going to tune.
What should the velues be 0?
and what i dont understand is the tables vaccum values only goes to 0.. what about when you are in boost?
Thank you,
Make sure that you change the neagative vales to something no lower than 0
