Flashpro + ID1000 = warm start issue
dermeister
Post by dermeister »
Hi
Currently running flashpro with ID1000 Injectors. using ID1000 FlashPro basemap, we went to dyno and got it tuned. Car idles and runs great. cold starts are perfect.
the problem i have is with warm/hot starts. when starting the car after 15 min after it has been used it takes several cranks to start.
ive been searching the forums etc.. and for what i understamd the problem lies with ID dead times numbers. I even seen people saying to put less than 1000cc on the flashpro for injector size.
please help with the correctikns you guys should be made.
regards
VitViper
Re: Flashpro + ID1000 = warm start issue
Post by VitViper »
It's not a dead time issue, it's a warm start cranking tuning issue.
dermeister
Hi,
Could you please point me to the right direction on where is this setting?
Thanks!
There are tables you can adjust under the fuel section in the calibration window: air temerature compensation and coolant temperature compensation.
dermeister
Hi,
Tried fixing this but no luck... im posting a datalog from a warm startup, (172 ECT/138 IAT) it cranks for almost 10 seconds.
What setting would you guys change? I have the settings from the Hondata ID1000 calibration map...
