Innovate MTX-L gauge correct but not reading in S300..
boost_jnky
Post by boost_jnky »
I wired up my wideband using the D10 connector to the ECU. The gauge reads fine. The display while datalogging in my Hondata is way off though. It is showing 1.48 while my gauge is showing 13.5 for example. Even when I rev the engine it shows very little change to the AFR on the display screen. I'm completely new to Hondata so any and all help is greatly appreciated .
mitsuman
Re: Innovate MTX-L gauge correct but not reading in S300..
Post by mitsuman »
boost_jnky wrote:I wired up my wideband using the D10 connector to the ECU. The gauge reads fine. The display while datalogging in my Hondata is way off though. It is showing 1.48 while my gauge is showing 13.5 for example. Even when I rev the engine it shows very little change to the AFR on the display screen. I'm completely new to Hondata so any and all help is greatly appreciated .
they HAVE to be connected to the same power and ground.
for power, tap into A25
for ground, tap into A24
Make sure that you selected D10 under wideband input source in s300.
this should help
http://www.xenocron.com/install/Xenocro ... -Guide.htm
Check your settings in the Options, Settings, Units, and make sure they are set to AF.
Check your settings in the sensor list by double clicking on AF and making sure the units are set to AF.
boost_jnky
Spunkster wrote:Check your settings in the Options, Settings, Units, and make sure they are set to AF.
Ok I changed it in the settings. Do I need to adjust the display min/max? It's currently set to :display min - .7 and Display Max - 1.4
This seems a little off.
yes you will have to change the min max to somethign like 10 and 20.
