reinstalled resistor box injectors not firing!
dvjr84
Post by dvjr84 »
So as the title states I just reinstalled a resistor box after switching back to low ohm injectors and I cant get them to fire with the resistor boxes (tried about 8) plugged in. When I had used the high ohm injectors my tuner had cut out the resistor box and wired the five wires together. I can only get them to fire this way for testing. Am I missing something? I changed the injector size in smanager and dead pulse. Is there anything else I should be changing? I dont have the car in front of me to get the serial number of the s300 but ill try and provide as much info as possible. Attached my calibration
Re: reinstalled resistor box injectors not firing!
This sounds like a wiring issue. Check everything that you have done.
http://www.hondata.com/techinjectorwiring.html
dvjr84
Post by dvjr84 »
Thing is I didnt do much but reinstall the resistor box. I can get them firing with the wires tied together as demonstrated in second picture but when I plug in the box nothing happens. When I initially had switched to high ohm injectors my tuner had cut the box out and wired the 5 wires. Im assuming all I had to do was plug in a resistor box right or was there something else I had to do? Damn the pictures are huge sorry
