AFR leaning out
toanz28
AFR leaning out
Post by toanz28 »
Hi
Recently I've encountered my AFR leaning out ( above 17:1 ). During those times, the car hesitates pretty bad, seems like
a misfire. This issue is intermittent, doesn't occur all the time. But I have been able to datalog some files as to when its
happening. Just wondering if i can get some tips as to where to look. either Ignition side or Fuel side.
Built H22 Turbo
p28 w/ s300
Stock ignition
RC750 cc injectors ( I think this may be the culprit )
Heres the calibration and some datalogs
Re: AFR leaning out
What whideband are you using and why not run closed loop off the wideband signal?
toanz28
Re: AFR leaning out
Post by toanz28 »
Hi
I'm using PLX DM-6.
I have it installed as per the instructions. As for the settings in the parameters, That is how the tuner left it.
Any advice?
Re: AFR leaning out
Try changing it to run closed loop off the wideband signal instead.
