knock sensor no signal ?
newage
Post by newage »
i have stock b20b with p72 ecu with s300v2 when i active knock sensor no chick engine and no signal for knock sensor all connoted with d3 pin out pls I need help
Re: knock sensor no signal ?
Where is the knock sensor installed?
newage
Post by newage »
I install it in same pals for knock sensor but after open s manager I see knock sensor without any voltage no voltage com from Ecu or sensor
