b20b on e85 bogging when shifting only after update
Posted: Tue Oct 15, 2013 6:01 pm
by cst1200mph
i have a b20b 12;0.1 comp stock top end im having problems with it bogging when i shift only when im at high rpm it runs fine at lower rpm butt i noticed that it started happening when the last update came out for the s300 i already took the distributor apart to make sure nothing was wronge with it and everything checks out so let me know if you have any ideas
Re: b20b on e85 bogging when shifting only after update
Posted: Wed Oct 16, 2013 12:19 pm
Posted: Sun Oct 20, 2013 8:49 am
by cst1200mph
im not trying to report a problem im just trying to see if anyone els has this problem because i know its not a problem with the ecu or the software because i had just sent the ecu in to get fixxed at the beginning of the summer so i guess what im asking is maybe if there was something new in the update that could be causing it that maybe isnt adjusted right i attached my tune so you can take a look at it any help would be great thanks
