traction control ecu?
gotslicks
Post by gotslicks »
hello
exactly what ecu will not work with traction control?
Re: traction control ecu?
All ECUs work apart from the PNF.
gotslicks
Post by gotslicks »
thanks for the quick reply.
so the pnf Honda si ecu will definitely not work.
reading thru the posts online they say that any ecu with the eld pin can work.
what is it in the pnf that makes it incompatible.
is there any chance to use another pin or something to wire it in?
i am only asking because i am about order tc for my track car but was gonna install in my daily ep3 si during winter to check it out.
sorry for all the questions.
The PNF ECU will work, but you cannot upload or tune with a PNF based calibration. You must use a PRB calibration.
groovezog1
Post by groovezog1 »
Spunkster wrote:The PNF ECU will work, but you cannot upload or tune with a PNF based calibration. You must use a PRB calibration.
Is there any way to change a PNF calibration to a PRB calibration? Could I do it myself or is it possible to send you the file and have you adjust it? Could I send you the ECU and have it upgraded in any way?
I already have a tune on a PNF ECU and I just bought and installed the Traction Control. What would you suggest I do?
You can try importing the tables from your calibration into a PRB calibration but you will probably need to fine tune things a bit on the dyno. We do not convert calibrations here. There are also no ECU upgrades that can be done to make the PNF work differently. You should talk to your tuner about helping you with this.
