Kmanager wont connect to ECU
3k1n
Post by 3k1n »
After installing a newer version of the Kmanager it seems like the Kmanager will not connect to the ECU. I have been using the same USB cable that was previously used while the Kmanager was still able to make a connection with the ECU. I'm receiving the following message when its trying to connect "The calibration in the ECU (3.1.2.0) is from an older version of Kmanager. Please update the ECU Calibration before data logging from this ECU."
I've downloaded the most current version of the Kmanager.
Re: Kmanager wont connect to ECU
Have you uploaded your calibration to the ECU using this new version as the message is telling you?
