Overrun Fuel Cut Delay settings
chneo1982
Post by chneo1982 »
There are 2 lean spikes whenever i shift as shown above.
From the log i estimated my gear shift to be around 0.5s.
What is a good overrun fuel cut delay time to eliminate these spikes? My current setting is at 180ms.
Please advise. thanks!
Re: Overrun Fuel Cut Delay settings
IT is normal to get a lean reading when you shift gears as you are no longer under load.
chneo1982
Post by chneo1982 »
Then am I right to say overrun fuel cut only helps squirting fuel when decelerating to cool engine head?
How much delay would cause back firing?
You really do not want fuel spraying durring decel as it is not needed. It is shutting off as you can see in the datalogs.
chneo1982
Post by chneo1982 »
I am trying to spray more and longer to cool the engine during deceleration.
Will this be bad for my O2 sensors?
It washes the oil off the cylinder walls and causes ring wear.
chneo1982
Post by chneo1982 »
But does it really help in cooling the engine? I am using this map only for track.
Engine cooling is mostly moot when you have 70% leakdown.
chneo1982
Post by chneo1982 »
What about a perfectly healthy engine?
He's telling you that washing the bores down will damaged the engine and negate any benefits.
chneo1982
Post by chneo1982 »
I see.... thanks for the advice!
