primary sensor shows 0 voltage , no change while running
perspective
Post by perspective »
I have a ep3 with stock k20a3, injen sri, hks exhaust. I have both o sensors plugged
Before kpro I had a check engine light, it was for either the primary or secondary o sensor.
Now after kpro III, No check engine light but when running a datalog I can't see any voltage on primary o sensor
this means either the wiring or the sensor are faulty right? please help
Re: primary sensor shows 0 voltage , no change while running
sounds logical.
perspective
I still get afr readings, and the car runs fine. Secondary o2 is working .
I don't get any codes or errors. If the primaryo2 sensor was faulty wouldn't the car run bad???
What is the exact error code you are getting?
perspective
I don't get any codes now. I'm using prb with the kpro. With my pnf I had a code for the o2 sensor , I do not remember which one (believe it was for the secondary o2).
Ugh I guess I need to put back the pnf to find out the code....
This is a DD , and I'm afraid I'll damage the engine
