issue with the cpr and s300.....
spoolinhatch13
Post by spoolinhatch13 »
Ok....I have s300 on p28. I switched to cop and ran everthing to spec. I go to start car and it just turns over. No sync light.
So from there I tried a 2 friends ecu's with s300 and sync light came on and fired the car right up. So I then put one of my buddies s300 board in my ecu and sync light came on and fired up. So I then put my s300 in his ecu and no sync light and no start. So I put everything back (my ecu with my s300) and tried again. No sync no start.
I then put my ecu with my s300 in another buddies car who is running just factory ignition, and it fired his car up. Just like it did with mine before I installed cop.
I'm not sure what to try now....any suggestions?
Re: issue with the cpr and s300.....
Have you changed the CPR settings in your calibration and uploaded it to the ECU?
spoolinhatch13
Yes. Doesn't sync other with map syncs
Post your calibraiton.
