Kpro boost control problem
xidmxi
Post by xidmxi »
I hooked up a Mac solenoid to kpro but it doesnt work.Its powered all the time when on II and disabling it from kpro doesnt make a diffrence it stays on.I heard both Wires going to the solenoid should have +12v and the ecu from pin b21 should ground to activate the solenoid but I tested pin B21 and its grounded all the time it never has the 12v. What could be the problem?
05typeR
Re: Kpro boost control problem
Post by 05typeR »
We're making a release in the next few days to fix this.
xidmxi
Post by xidmxi »
Thanks!!!
turbosi05
Post by turbosi05 »
I am having the same problem even with the new release. The solenoid pulses a few times when the ignition is turned on. Then stays on continuously afterwards.
Have you uploaded your calibration using the new version of software?
turbosi05
Post by turbosi05 »
Yes
From Help, about, what version of software are you using?
turbosi05
Post by turbosi05 »
3.3.0.0
Please post your calibration, as I cannot reproduce a problem here.
Nineteendc5
Post by Nineteendc5 »
I am having the same issue with the new 3.3.0
Tried it on 2 seperate laptops with 3.3.0, but i tried uploading the map on a laptop with 3.2.4 and it works perfectly. I need a fix asap!
maxime bougie
Post by maxime bougie »
same problems with the new version
The original problem was fixed some time ago. Make sure you have the latest software version, then follow the posting guidelines if you still have a problem.
