Just purchased Kpro having problems
Scottb21
Post by Scottb21 »
Hi there, i have just recieved my kpro back from being fitted at CPL in the uk, i have a uk spec 03 plate type R, i followed all instructions and updated my kmanager software to the beta, when i connect to my ecu it always says "ignition off" but driver etc works, it has a base map which cpl has put on which i'm guessing is to test it, so currently i have a 4000rpm limiter, i really need this to connect any help would be much appreciated. I have also tried using the software before the beta
Re: Just purchased Kpro having problems
You will need to contact CPL for assistance with this, as this should have been tested and working when they sent it to you.
