2000 Ek hatch with k20a2 motor n Tranny using prc ecu
rafajdmboosted
Post by rafajdmboosted »
I'm new to the k series I just recently put a k20a2 motor n Tranny in my Ek n the problem Im running to which I have check threads but Im a little confused is Im using a prc ecu Im using a k20a2 harness I read bout grounding the wires but that's were Im stuck on Wat wires have to be grounded so that my fuel pump can kick on so I can get fuel is there a easy way around this or Wats my best bet I appricate the help
Re: 2000 Ek hatch with k20a2 motor n Tranny using prc ecu
Are you using a K-Pro?
rafajdmboosted
No I was told I can use a stock prc ecu which I guess is the type r version of k seires Im new to this Im sorry Ima b series guy Lol I was told I have to ground out the fuel pump or something in that nature is there a way around It ?
