ABS Module Wiring 2013 Si
08si
Post by 08si »
Hello, I am looking to order/install the TC shortly. Does it include the OEM wiring color coded instructions for a 2013 Si? If not could you please reply with the proper OEM wiring color designations?
Thank you.
Re: ABS Module Wiring 2013 Si
Terminal number Wire color Terminal sign Description Signal
1 BRN ABS_GND Ground for the VSA modulator-control unit Continuity to ground
2 BRN ABS_GND Ground for the pump motor Continuity to ground
3 WHT +B_ABS/VSA_FSR Power source for the fail-safe relay Battery voltage (about 12 V) at all times
4 RED +B_ABS/VSA_MTR Power source for the motor relay Battery voltage (about 12 V) at all times
5 Not used Not used ――― ―――
6 Not used Not used
7 Not used Not used
8 GRY IG1_VSA/ABS Power source for activating the system With ignition switch ON (II): battery voltage (about 12 V)
9 Not used Not used ――― ―――
10 WHT F_CAN-H F-CAN communication circuit
11 LT GRN RR_R_ABS_SNSR+ Detects right-rear wheel speed sensor signal
12 ORN FR_L_ABS_SNSR+ Detects left-front wheel speed sensor signal
13 BLU RR_L_ABS_SNSR+ Detects left-rear wheel speed sensor signal
14 GRN FR_R_ABS_SNSR+ Detects right-front wheel speed sensor signal
15 RED F_CAN-L F-CAN communication circuit
16 LT BLU K_LINE Communication with HDS Pulse voltage (digital signal)
17 WHT RR_R_ABS_ SNSR- Detects right-rear wheel speed sensor signal ―――
18 GRY FR_L_ABS_ SNSR- Detects left-front wheel speed sensor signal
19 PUR*1 GRN*2 RR_L_ABS_ SNSR- Detects left-rear wheel speed sensor signal
20 Not used Not used ―――
21 PNK FR_R_ABS_ SNSR- Detects right-front wheel speed sensor signal
22 Not used Not used ―――
08si
Post by 08si »
Thank you for the detailed reply. If I am reading this correctly, the first four are the positive connections and the last for are the negative, is this correct? Also, would I be right in assuming that - 19 PUR*1 GRN*2 - is a two color wire?
green for SI and purple for a non-SI.
08si
Post by 08si »
Thank you sir.
08si
Post by 08si »
Hello again,
I also wanted to confirm, are the sensors classed as active or inductive? and that the ELD is A34?
Thank you.
08si
Post by 08si »
Thanks again!
08si
Post by 08si »
Can you please confirm the ELD input location for my application? Also, do I tap into the existing ELD wire or remove it from the ecu and replace it?
Complete details of the pins can be found at http://www.hondata.com/help/flashpro/ecu_connectors.htm
08si
Post by 08si »
Thanks, I still have a couple questions -
"ELD must be disabled" - this means in my FP calibration correct?
"factory pin must be removed from the ECU connector" I am confused by this - If I completely remove the factory pin and wire, where/what do I wire the TC's ELD wire to? It wasn't shipped with a pin to replace it..
So again, do I tap into the wire (meaning having two wires connected to the ELD) or do I cut the original wire lead, leaving the factory pin inserted leaving a few inches of wire in place to connect to and leave the other end of the original wire disconnected?
I apologize if I am missing the obvious, I just want to be clear.
http://www.hondata.com/civic_pin_request_info.html
You should depin the wire and pin form the harness and use one of the pins in the above link to wire this into the ECU plug.
Yes you need to disable the ELD in the calibration.
Details on how to send a self address stamped envelope can be found at: http://www.wikihow.com/Send-an-S.A.S.E. ... -Envelope)
08si
Post by 08si »
Roger. Thank you for that.
One problem. I live in Canada. I can't provide a S.A.S.E as your postal system will not honor Canadian postage stamps/markings.
May I please make a humble request that you post these out to me?
08si
Post by 08si »
If cost is an issue, I can pay for the shipping if you send me a Paypal invoice....
As a friendly suggestion, you might want to consider sending these in the TC packages as everyone will need them as per your install instructions. Its not really complete without them.
You can use an internal reply coupon from the Canadian postal service.
http://www.canadapost.ca/tools/pg/manua ... eply-e.asp
We cannot include every type of pin for all vehicles with the traction control system.
