09 tsx flashpro on 2011 k24z3 accord
indodarknight
Post by indodarknight »
I have a 2011 honda accord lx-s 5spd manual with k24z3 stock motor
the thing is, I've tried to you aem fic to tune, and failed, because there is no base map to start off with
I have turbo on my car right now, and did plenty of research on the build, so what I came up with
is replacing my oem plastic manifold with the rbc manifold, with the prl adapter, I wasn't too hard
but then I've notice that the 2008-2013 tsx has the same motor as mine, and hondata has a flash pro for the 08-09 ecu
so what I did was, plug in the 09 6spd tsx ecu into my car, and get it reprogram by honda dealer, and now its running pretty well,
except a few minor flaws:
- slightly heavier powersteering (due to tsx having electronic p/s)
- mph speedo meter is off by 20-30 mph (maybe fixable with speed sensor)
surprisingly, ac/heater, radio and all of those other things works
now, the question, is, since I have the 09 tsx ecu with the code that match the flash pro,
will I be able to tune the car with it?
I've spend so much money already, and $695 price is a bit steep to test and fail,
can I have some of the hondata specialist to chime in plz?
thanks,
tommyt
Re: tsx flashpro on accord
Since it is not designed for this type of swap it may not work correctly and there may be things that cannot be corrected. You do this at your own risk. This is not recommended or supported by Hondata.
indodarknight
i c
so, i was wondering, if you guys are gonna have a flash pro for our car?
2008-2012 k24z3 accords?
I know you guys just recently finish the 03-07 accords and even the euro/jdm 08-10 accords
so we have hope right? just gotta wait our turn?
It is something we may look into in the future, but there is currently nothing in development.
indodarknight
i c, thanks
so the tsx flashpro is still the better bet,
before I blow something up,
thanks for the responds
indodarknight
I know, I'm a bit hard headed, and went on buying hondata flashpro from vit viper
but I've been getting the wen error, I've read all the tsx forums, including the one here on hondata about the error
and I've tried all the troubleshoot that everyone recommend,
the thing is, the wen pin on my obd2 read 4.1 volt (I've test some other accord my year and they rear between 4-4.2 volt) so that should be right
and the flashpro can read my cel and such, it even lock unto my 09 ecu
but now, that it still not working, I'm trying to unlock it from the ecu, and it keep on giving me the same error
help plz,
just incase, here is my flashpro serial# FP-TSX-US-90294
can you check if that is the right one for the 6spd manual 2009 tsx?
thanks
Re: 09 tsx flashpro on 2011 k24z3 accord
Put the ECU into an 09 TSX and return it to stock and unlock it. We do not support a 2011 Accord.
