help wiring aem 150psi sensors to s300 V2
94turboeg
Post by 94turboeg »
I cant figure out how to wiring up the two sensor correctly to s300 V2 analog inputs so they will work. I tried wiring it up the same way as the autometer sensor it isn't working I need some insight.
Re: help wiring aem 150psi sensors to s300 V2
Please provide part numbers and a link to the manual for these sensors.
94turboeg
Post by 94turboeg »
Spunkster wrote:Please provide part numbers and a link to the manual for these sensors.
http://www.aemelectronics.com/150-psig- ... or-kit-650
AEM Part Number 30-2130-150
How exactly do you have them wired? Where are you getting your 5v power from?
94turboeg
Post by 94turboeg »
Spunkster wrote:How exactly do you have them wired? Where are you getting your 5v power from?
I tried to hook it up like the autometer psi sensor D19 for 5v and B2 for the ground with NO SUCCESS.
94turboeg
Post by 94turboeg »
Any ideas ?
Try a signal ground instead, D21 or D22.
94turboeg
Post by 94turboeg »
Spunkster wrote:Try a signal ground instead, D21 or D22.
Where should I get the 5v from?
The same place you were before.
94turboeg
Post by 94turboeg »
Spunkster wrote:The same place you were before.
Well I try it again, but with both sensors connected my fuel pump circuit wouldn't work
It sounds like you don't have it wired correctly then.
