ID 2000cc problem.
leetec
ID 2000cc problem.
Post by leetec »
I have bought a set of ID 2000cc injectors for my boosted k 2.2. The problem I'm having is trying to get the fueling down as the its running very rich on idle. The injector duty is 1%, does not matter what figure I put in the fuel table I can't get it to lean off.
any help with be much appreciated.
you can turbo a VTEC........but you cant VTEC a turbo :D
Re: ID 2000cc problem.
Have you set the dead times correctly?
leetec
Post by leetec »
it was the dead times that where provided with the injectors from ID.
That may be the problem, the dead times supplied by them in the past have been incorrect.
You may want to read more about this at http://www.hondata.com/forum/viewtopic. ... dead+times
leetec
Post by leetec »
ok great thank you i'll give it a try
