ECU Questions?
GermanCRX
ECU Questions?
Post by GermanCRX »
Hello i have a question: (sorry for my grammar i am from germany)
my car is an Honda CRX ED9 90 D16Z5 turbocharged . ECU is change to P28 with S300. Everything is working and ECU is tuned.
Question:
1. I want to use the digital inputs and the output for boost controll.
MY ECU nuber is 37820-P28-G02-766-306087 AWR (denshigiken) is this ecu JDM or USDM?. I think it is an JDM but iam not sure.
2. Outputs: When i make the hook in the case is the output aktiv?
must the engine run in idle at 850rpm?
3. Inputs: when i connect the input to minus/ground it is switched on?
Is it possible to see that it is realy aktivated?
Thank you for your answers best reguards from germany
Re: ECU Questions?
That ECU is not a JDM ECU. It should be similar to USDM and in a rectangular case.
The digital inputs on a s300 cannot be used for boost control. Boost control is a pulse width modulated output that is part of the ECU itself.
Details can be found at:
http://www.hondata.com/help/smanager/bo ... st+control
