How can I convert the Wideband into a readable format
Mafia
Post by Mafia »
So I have my Wideband setup and wired into D10, I made sure my conversion is on too.
What im trying to do is set something up in the "display" so I can see if im lean or rich. All its letting me do is show the volts. (I made a "value" for ELD and lambda voltage. And they both display the same voltage)
I have volt input in parameters, closed loop advanced set to what the gage calls for. Thanks!
S300 V1 on 2.2.7.0
Eg 800hp - Track car
Eg 580hp - daily
Re: How can I convert the Wideband into a readable format
You need to use the AF sensor reading. If you load one of the built in display files you will see how it looks.
