Failsafe input
saintjah
Failsafe input
Post by saintjah »
With Kpro III on a 2003 S2000, is the integrated failsafe input compatable with the AEM failsafe? The AEM failsafe will trigger a -1.5v ground once it has reached a specified parameter. Running the failsafe wire to the input in Kpro pin specified, would this set up work properly or is it only functional in an RSX application?
Re: Failsafe input
Yes it should also work on an S2000 with K-Pro.
saintjah
Re: Failsafe input
Post by saintjah »
What pin to you recommend for connecting the fail safe input into the Kpro ecu?
Re: Failsafe input
What pin you use is totally up to you, as long as it is one of the inputs listed in the software.
