On board data log doesnt log analog inputs
9queSt
Post by 9queSt »
I have my fuel pressure sensor hooked up to Analog 0 on the s300. When i hook up the laptop and record the log I get a good fuel psi read but when I use on board data log it flat lines. I tried both raw voltage and psi but both flat lined on the on bord log.
on s300 "upload calibration to s300 after uploading" is checked.
Re: On board data log doesnt log analog inputs
From Help, about, what version of software are you using?
