SManager V2.2.8
SManager V2.2.8
SManager V2.2.8 (10 Feb 2014)
  • Fixed lean protection.
  • [Traction Control] Firmware 10
  • [Traction Control] Fixed vehicle speed determination method not showing correctly after update.
  • [Traction Control] Prompt to write unsaved Traction Control configuration changes when application closed.
Download here
skullbasher
Re: SManager V2.2.8
Post by skullbasher »
Can u explain what changes were done to the lean protection?? and will the MIL blink under Sensors? I wasn't able to see if the Check engine light blinked but I recorded it and im trying to see if it was due to the lean protection that my engine cut off.
Re: SManager V2.2.8
Lean protection previously worked, but a bug was introduced in the previous version that was corrected in this version. You will need to review your datalog to see what was actually happening.
