ecu check
Klatano
ecu check
Post by Klatano »
37820-rrb-a12-4744-113586
I bought a 2007 civic si witha blown engine, it had a supercharger. now I replaced it with a stock engine. Can you check the ecu for me. how much to reflash it? or can I buy a flashpro, flash it to stock and sell the flashpro?
Re: ecu check
I have no record of that ECU. Have you tried this ECU with the stock engine?
Klatano
Re: ecu check
Post by Klatano »
yeah. The engine wants to start, the only way i could keep it running was by almost completely covering the intake intake. There is no way to tell if the previous owner used a flashpro? when it does run its smooth.
Re: ecu check
Are you removing the AFM or altering its flow path?
Klatano
Re: ecu check
Post by Klatano »
the afm is in the same place as stock. The engine will start when I cover the intake or airbox intake tube.
Re: ecu check
post a picture of the engine bay
Klatano
Re: ecu check
Post by Klatano »
I will when I get a chance. Thanks for your help
Klatano
Re: ecu check
Post by Klatano »
here is a picture. ignore the plastic line in the middle. I think it was for the vacuum gauge . I can get the car started by covering almost completetly covering the intake so it getting spark and fuel.
Re: ecu check
The AFM is not bolted down. The tube after the AFM to the fast idle valve is missing. Both those things will stop the vehicle from running correctly.
Re: ecu check
You do not have the AFM secured properly, and also you have a major air leak where a hose is supposed to be attached to the intake tube.
Klatano
Re: ecu check
Post by Klatano »
I was messing with the airbox before I took the picture. The AFM was secure and the tube was in place. Lets suppose everything is connected correct. Do you think I if the ecu was setup for a superchager, would that prevent the engine from starting or I should trouble shoot something else. It runs smooth when it does run.
Re: ecu check
If it is returned to stock you should unlock the FlashPro and get it to a Honda dealer so they can troubleshoot this for you.
Klatano
Re: ecu check
Post by Klatano »
its has not being returned to stock. My question was if the ecu was tuned for a supercharged overbored to 2.4L engine. would that give me the problems I am having ?
