Kpro Launch Control
shaunrsxtypes
Kpro Launch Control
Post by shaunrsxtypes »
What input(sensor, switch, etc.) is used to use launch control? In the help section it says it's not suitable to use the start/clutch kill switch and cruise control cut switch but instead to use a micro switch. If I were to use a micro switch which circuit would this tie into? Thanks.
Re: Kpro Launch Control
You must wire the clutch switch into one of the 4 inputs listed in the software.
shaunrsxtypes
Awesome thank you!
