FN2R AUDM FLASHPRO
OzFn2r
FN2R AUDM FLASHPRO
Post by OzFn2r »
Hi all,
Need some help.
I recently purchased a FN2R with a Flashpro installed. The seller advised that he used the preloaded tune on the Flashpro. All he did was select his intake, headers and exhaust, and the software did the rest.
I have since downloaded the Flashpro software and returned the ECU to stock. This has yielded a CEL. I suspect this is a result of the modifications.
I have tried reflashing the ECU with an appropriate pre-loaded tune. When i launch the software i dont get an option to choose between AFM or MAP based tunes, and as soon as i select a Injen CAI, i have zero options to select from out of the pre-loaded list.
I have tried this for all the versions of the FN2R - Asia, Europe and South Africa. Cant help but notice an Australian delivered model is missing?
I have tried the software on multiple occasions, including re-installs. I've also used different laptops. Still dont get any pre-load options.
Please help.
OzFn2r
Re: FN2R AUDM FLASHPRO
Post by OzFn2r »
I should add that part of the reason i returned to stock was because of the fuel efficiency gauges not working, which i believe is a known issue on a MAP based tune. I wanted to retune on a AFM basis, but like i said, no pre-load options?
You must use one of the base calibrations that does not have RACE in the name.
OzFn2r
Post by OzFn2r »
Is there a risk to just choosing any calibration...?
You just won't be able to tune using the method you want if it is a race calibration.
