Innovate MTX install s300 ?
Reiko
Post by Reiko »
How should I connect the MTX when I use original O2 sensor?
Yellow (Analog 1 Wideband 0-5V) = Connect to D12 EGRL
Brown (Analog 2 Narrowband 0-1V) = Connect to ???
Black (Ground/Logical Ground) = Connect to A26
White (Cluster Guage/Headlight Power) = Connect to A25
Red (12V Power/Ignition Power) = Connect to A25
Thanks Reiko
Re: Innovate MTX install s300 ?
http://www.hondata.com/techplxwiring.html
Follow that and just substitute the colors for the ones on the MTX.
Reiko
Post by Reiko »
Do I understand that they cannot be used together?
Brown connect to D14 and remove original O2 sensor?
You can run closed loop form the wideband signal. You do not need anything connected to the D14 input.
